Ensure that you enable DvR globally on the node.
View DvR host entries (IPv4 remote host routes) on either a Controller or a Leaf node. The node displays the host entries learned either locally on its Switched UNI port or dynamically from other nodes within the DvR domain.
  1. Enter Privileged EXEC mode:
    enable
  2. View the DvR host entries.
    On a Controller:
    show dvr host-entries [domain-id <1–255>]|[ipv4 {A.B.C.D}]|[l2isid <1-16777215>]|[l3isid <0-16777215>]|[nh-as-mac]|[type <1–2>]|[vrf WORD<1-16>] [vrfids WORD<0-512>]
    On a Leaf node:
    Viewing the DvR host entries for a specific VRF or VRF ID is not supported on a DvR Leaf node.
View DvR host entries on either a Controller or a Leaf node.
Switch:1#show dvr host-entries domain-id 255 l3isid 55500
                                                         DVR Host-Entries
                 HOST                L3VSN      L2VSN                           DOMAIN
IP-ADDRESS       MAC-ADDRESS         ISID       ISID       VRFID      PORT      ID         TYPE       NEXT HOP
50.0.1.2         b0:ad:aa:42:ed:04   55500      50500      0          1/23      255        DYNAMIC    Cont-1:121
50.0.1.3         b0:ad:aa:4c:3d:01   55500      50500      0          cpp       255        LOCAL      Cont-2:122
2 out of 2 Total Num of DVR Host Entries displayed
View DvR host entries for a specific IP address.
In this example, you enter IP address 50.0.1.0 to display host entries for IP addresses 50.0.1.2 and 50.0.1.3.
Switch:1#show dvr host-entries ipv4 50.0.1.0
                                                         DVR Host-Entries
50.0.1.2         b0:ad:aa:42:ed:04   55500      50500      0          1/23      2          DYNAMIC    Cont-1:121
50.0.1.3         b0:ad:aa:4c:3d:01   55500      50005      0          cpp       2          LOCAL      Cont-2:122
View DvR host entries where the next hop displays the MAC address instead of the system name.
Switch:1#show dvr host-entries nh-as-mac
                                                         DVR Host-Entries
50.0.1.2         b0:ad:aa:42:ed:04   55500      50500      0          1/23      2          DYNAMIC    00:bb:00:00:01:01
50.0.1.3         b0:ad:aa:4c:3d:01   55500      50500      0          cpp       2          LOCAL      00:bb:00:00:01:02
View DvR host entries based on the host type. Type 1 indicates local hosts and type 2 dynamic hosts.
Switch:1#show dvr host-entries type 2
                                                         DVR Host-Entries
1 out of 2 Total Num of DVR Host Entries displayed
Variable definitions
Use the data in the following table to use the show dvr host-entries command.
Variable
Value
domain-id
Specifies the domain ID of the DvR host entry.
The range is 1 to 255.
ipv4
Specifies the IP address (IPv4) of the DvR host entry.
l2isid
Specifies the Layer 2 VSN I-SID of the DvR host entry.
The range is 1 to 16777215.
l3isid
Specifies the Layer 3 VSN I-SID of the DvR host entry.
The range is 0 to 16777215.
nh-as-mac
Specifies the MAC address of the next hop node instead of the system name.
type
Specifies the host type of the DvR host entry.
A value of 1 indicates local hosts and a value of 2 indicates dynamic hosts.
vrf
Specifies the VRF name of the DvR host entry.
vrfids
Specifies the VRF ID of the DvR host entry.
The range is 0 to 512.
